Ga door naar hoofdinhoud
How to Remove Calcium Buildup from a Shower Head
Wat je nodig hebt
  1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: stap 1, afbeelding 1 van 2 How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: stap 1, afbeelding 2 van 2
    • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
    • You may be able to loosen the shower head by hand.
    • Handle carefully because the shower head may be heavy.
  2. How to Remove Calcium Buildup from a Shower Head: stap 2, afbeelding 1 van 1
    • Use your hands to finish unscrewing the bolt.
    • Remove the shower head from the wall spout.
  3. How to Remove Calcium Buildup from a Shower Head: stap 3, afbeelding 1 van 3 How to Remove Calcium Buildup from a Shower Head: stap 3, afbeelding 2 van 3 How to Remove Calcium Buildup from a Shower Head: stap 3, afbeelding 3 van 3
    • Pour one cup of water into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the water.
  4. How to Remove Calcium Buildup from a Shower Head: stap 4, afbeelding 1 van 3 How to Remove Calcium Buildup from a Shower Head: stap 4, afbeelding 2 van 3 How to Remove Calcium Buildup from a Shower Head: stap 4, afbeelding 3 van 3
    • Pour one cup of distilled vinegar into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the solution.
    • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
  5. How to Remove Calcium Buildup from a Shower Head: stap 5, afbeelding 1 van 2 How to Remove Calcium Buildup from a Shower Head: stap 5, afbeelding 2 van 2
    • Place the shower head face down into the plastic bag of vinegar solution.
    • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
  6. How to Remove Calcium Buildup from a Shower Head: stap 6, afbeelding 1 van 1
    • After one hour, remove the shower head from the plastic bag of vinegar solution.
    • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
    • Excessive scrubbing could damage the finish.
  7. How to Remove Calcium Buildup from a Shower Head: stap 7, afbeelding 1 van 2 How to Remove Calcium Buildup from a Shower Head: stap 7, afbeelding 2 van 2
    • Place the shower head under running water to remove any extra calcium left behind.
    • If calcium is still present, repeat steps 5 through 7 as needed.
  8. How to Remove Calcium Buildup from a Shower Head: stap 8, afbeelding 1 van 2 How to Remove Calcium Buildup from a Shower Head: stap 8, afbeelding 2 van 2
    • Clamp the adjustable wrench onto the bolt of the shower head.
    • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Jacob Abrego
150 Reputatie
1 Handleiding geschreven
Texas Tech, Team 26-6, Rauch Spring 2016 Lid van Texas Tech, Team 26-6, Rauch Spring 2016
TTU-RAUCH-S16S26G6
3 Leden
4 handleidingen geschreven
Één opmerking
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 90
Altijd: 9,181
