Ga door naar hoofdinhoud
How to Reinforce the Base of a Torn Backpack
Wat je nodig hebt
  1. How to Reinforce the Base of a Torn Backpack, Backpack Base: stap 1, afbeelding 1 van 1
    • Pull out any excess thread that is left over from the tear.
    • Make sure to be careful in pulling the thread to avoid causing excess damage.
  2. How to Reinforce the Base of a Torn Backpack: stap 2, afbeelding 1 van 1
    • Turn the backpack inside out.
    • Carefully do this to not make the hole bigger.
  3. How to Reinforce the Base of a Torn Backpack: stap 3, afbeelding 1 van 2 How to Reinforce the Base of a Torn Backpack: stap 3, afbeelding 2 van 2
    • Pin the hole together using sewing pins.
    • Gently pin to avoid poking or hurting yourself with the pins.
  4. How to Reinforce the Base of a Torn Backpack: stap 4, afbeelding 1 van 2 How to Reinforce the Base of a Torn Backpack: stap 4, afbeelding 2 van 2
    • Thread your needle with a similar color thread to your backpack.
    • Tie a knot at the end of the thread.
  5. How to Reinforce the Base of a Torn Backpack: stap 5, afbeelding 1 van 3 How to Reinforce the Base of a Torn Backpack: stap 5, afbeelding 2 van 3 How to Reinforce the Base of a Torn Backpack: stap 5, afbeelding 3 van 3
    • Sew the hole shut, removing pins as you go.
    • Use this Basic Sewing guide for exact stitching.
    • Unpin carefully to avoid poking or hurting yourself with the pins
    • Tie a knot at the end to close off the stitch.
    • Cut any excess thread.
  6. How to Reinforce the Base of a Torn Backpack: stap 6, afbeelding 1 van 3 How to Reinforce the Base of a Torn Backpack: stap 6, afbeelding 2 van 3 How to Reinforce the Base of a Torn Backpack: stap 6, afbeelding 3 van 3
    • Trace an additional piece of lining with ¼” seam allowance in the shape of the backpack bottom.
    • Cut the fabric for the lining.
    • Pin the fabric around the perimeter to the base of the backpack.
  7. How to Reinforce the Base of a Torn Backpack: stap 7, afbeelding 1 van 1
    • Sew the lining to the base of the inside out backpack using the same process in Step 5.
    • Use this Basic Sewing tutorial as needed.
    • Gently sew and unpin to avoid hurting yourself with the pins.
  8. How to Reinforce the Base of a Torn Backpack: stap 8, afbeelding 1 van 1
    • Enjoy your newly strengthened backpack!
Conclusie
Congratulations you have now reinforced and repaired your backpack! Good as new if not better.
Amber Irfan
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-4, Andersen Winter 2024 Lid van UC Davis, Team 4-4, Andersen Winter 2024
UCD-ANDERSEN-W24S4G4
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 123
