Inleiding
In this repair, we will be reinforcing a microbead plush by creating a bag for the microbeads. Using this repair, we can extend the duration of items a loved one has given or keep these items in near-perfect condition. Before starting this repair, you should have a spool of a thread in the plush's color to make any repairs unnoticeable. This repair will take a while and can get messy; for example, when flipping the plush casing, use an area that is easy to clean.
Wat je nodig hebt
Look for seams in the microbead plush that you can tear to remove its contents.
Using a seam ripper, make a hole the size of your thumb.
Measure about 20 times the length of the plush in thread.
Push the thread through the eye of the needle until both sides of the needle have an equal amount of thread.
Create a small loop using the loose ends, leaving about 2 centimeters to wrap around the base of the loop. Push the excess through the loop to create a knot.
With those final stitches, your microbead plush shouldn’t spill anymore.
