Inleiding
If the weather and excess weight limits have damaged your hammock's rope, this guide will provide you a way to securely hang your hammock with material that will last longer and withhold larger weight capacities.
Using metal screw hooks and metal clasps that support larger weight limits and are mounted in the tree will allow you to get more use out of your hammock for a longer period of time.
Before starting this project make sure your power drill is fully charged. This will allow you to get a deeper cleaner hole into each side of the tree without breaking drill bits or having any issues with inserting the screw hole into the tree.
Also, you will want to make sure you find two trees that are at least 6-7ft apart to (or the appropriate distance of whatever size hammock you chose) to make sure the hammock sits up far enough from the ground.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
