Ga door naar hoofdinhoud
How to Rehydrate a Dried Eyeliner Pen
Wat je nodig hebt
  1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: stap 1, afbeelding 1 van 1
    • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
  2. How to Rehydrate a Dried Eyeliner Pen: stap 2, afbeelding 1 van 2 How to Rehydrate a Dried Eyeliner Pen: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the cap from your eyeliner pen.
    • Take a small pair of pliers and gently remove the felt rod from inside the liner.
    • Some liners may require you to unscrew the end of the liner to remove the felt rod.
    • If you do not have pliers, tweezers can also be used for this fix.
  3. How to Rehydrate a Dried Eyeliner Pen: stap 3, afbeelding 1 van 3 How to Rehydrate a Dried Eyeliner Pen: stap 3, afbeelding 2 van 3 How to Rehydrate a Dried Eyeliner Pen: stap 3, afbeelding 3 van 3
    • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
    • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
  4. How to Rehydrate a Dried Eyeliner Pen: stap 4, afbeelding 1 van 3 How to Rehydrate a Dried Eyeliner Pen: stap 4, afbeelding 2 van 3 How to Rehydrate a Dried Eyeliner Pen: stap 4, afbeelding 3 van 3
    • Take the felt rod out of the water and immediately place it on a paper towel.
    • Gently pat the felt rod dry using a paper towel.
  5. How to Rehydrate a Dried Eyeliner Pen: stap 5, afbeelding 1 van 2 How to Rehydrate a Dried Eyeliner Pen: stap 5, afbeelding 2 van 2
    • Lastly, use a plier to fit the felt rod back into the liner pen.
  6. How to Rehydrate a Dried Eyeliner Pen: stap 6, afbeelding 1 van 1
    • Now test out your new eyeliner pen to see the difference!
    • The red arrow shows the before and the blue arrow shows the after.
Eindstreep
Nuha Naushad
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 130
