Ga door naar hoofdinhoud
How to Refinish a Scratched Wood Table
Wat je nodig hebt
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: stap 1, afbeelding 1 van 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: stap 1, afbeelding 2 van 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: stap 1, afbeelding 3 van 3
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: stap 2, afbeelding 1 van 2 How to Refinish a Scratched Wood Table: stap 2, afbeelding 2 van 2
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: stap 3, afbeelding 1 van 3 How to Refinish a Scratched Wood Table: stap 3, afbeelding 2 van 3 How to Refinish a Scratched Wood Table: stap 3, afbeelding 3 van 3
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: stap 4, afbeelding 1 van 1
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: stap 5, afbeelding 1 van 1
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: stap 6, afbeelding 1 van 3 How to Refinish a Scratched Wood Table: stap 6, afbeelding 2 van 3 How to Refinish a Scratched Wood Table: stap 6, afbeelding 3 van 3
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
Eindstreep
Gurvir Boparai
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 51
Altijd: 1,144
