Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn Vape off by pressing the largest button 5 times in row quickly.
Cut two, 8 inch pieces of 24 gauge kanthal wire with the wire cutters.
Hold the screwdriver and the wire end in one hand (non dominant) and the loose end of the wire in the other hand (dominant).
Using the loose end of the wire, wrap 4-8 times (depending on desired ohms) around the screwdriver.
Leave wire wrapped around screwdriver and use fingernails to push the coil down towards base of screwdriver.
Repeat steps 3-6 with the other piece of wire, making sure to have the same amount of loops in both coils.
Unscrew the top four screws on atomizer without removing them.
Put one end of the coil in an outermost hole on side of screw and other end in one of the inner holes.
Tighten the screws completely once coils are in desired position.
Put the screwdriver through the coil to place the coil in desired position.
Re-insert the batteries and press the large button 5 times quickly to turn the vape on.
Press the biggest button on vape to heat up coils until red hot.
Use tweezers to compress the coils, being careful not to touch the tweezers to the coils while the button is being pressed.
Repeat on other side. Coils are ready when both sides glow red hot at the same time.
Once coils are cooled, tear a cotton strip from the large square and roll it with your hands until you have a tight but long strand.
Using the wire cutters, cut cotton approximately ΒΌ of an inch away from outside of atomizer on each strand.
Tuck cotton underneath coils and into the well of the atomizer using the tweezers.
Juice the cotton and coils completely with your favorite vape juice.
16 andere personen hebben deze handleiding voltooid.
