Inleiding
This guide shows how to rebuild a primer style carburetor on a Briggs and Stratton quantum engine. The guide is applicable to many different models and brands of mowers.
This engine can be found on push mowers, log splitters, tillers, leaf vacs, leaf blowers, tractors, and more. It is applicable to 4.5-8 horsepower engines. A carburetor rebuild is required after fuel is left in a mower over a long period of time or water has gotten into the fuel.
Wat je nodig hebt
The air filter and its cover are located to the right of the yellow warning label under the throttle cable.
Remove the single screw attaching the cover and filter using a 5/16'' socket.
Pull straight outward until the filter assembly is detached.
The throttle cable will be located above the air filter assembly.
Use a flathead screwdriver to remove the throttle cable.
Één andere persoon heeft deze handleiding voltooid.
