Ga door naar hoofdinhoud
How to Reattach a Cabinet's Center Stile
Wat je nodig hebt
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: stap 1, afbeelding 1 van 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: stap 1, afbeelding 2 van 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: stap 1, afbeelding 3 van 3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: stap 2, afbeelding 1 van 3 How to Reattach a Cabinet's Center Stile: stap 2, afbeelding 2 van 3 How to Reattach a Cabinet's Center Stile: stap 2, afbeelding 3 van 3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: stap 3, afbeelding 1 van 3 How to Reattach a Cabinet's Center Stile: stap 3, afbeelding 2 van 3 How to Reattach a Cabinet's Center Stile: stap 3, afbeelding 3 van 3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: stap 4, afbeelding 1 van 2 How to Reattach a Cabinet's Center Stile: stap 4, afbeelding 2 van 2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 54
Altijd: 1,203
