Ga door naar hoofdinhoud
How to Reattach Loose Book Pages
Wat je nodig hebt
  1. How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: stap 1, afbeelding 1 van 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: stap 1, afbeelding 2 van 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: stap 1, afbeelding 3 van 3
    • Open the book and remove the loose pages.
    • Make sure the pages are in numerical order.
    • Set the ordered loose pages aside.
  2. How to Reattach Loose Book Pages: stap 2, afbeelding 1 van 3 How to Reattach Loose Book Pages: stap 2, afbeelding 2 van 3 How to Reattach Loose Book Pages: stap 2, afbeelding 3 van 3
    • Squeeze some glue onto the inside of the book spine.
  3. How to Reattach Loose Book Pages: stap 3, afbeelding 1 van 3 How to Reattach Loose Book Pages: stap 3, afbeelding 2 van 3 How to Reattach Loose Book Pages: stap 3, afbeelding 3 van 3
    • Use a craft stick to spread the glue so that it covers the spine evenly.
  4. How to Reattach Loose Book Pages: stap 4, afbeelding 1 van 3 How to Reattach Loose Book Pages: stap 4, afbeelding 2 van 3 How to Reattach Loose Book Pages: stap 4, afbeelding 3 van 3
    • Set the ordered loose pages back in the spine.
    • Carefully line up the top and bottom of each loose page with those in the book.
    • You might need to wiggle or readjust them to make sure they are lined up.
    • Work quickly so that the glue doesnโ€™t dry and cause the pages to stick in the wrong place.
  5. How to Reattach Loose Book Pages: stap 5, afbeelding 1 van 3 How to Reattach Loose Book Pages: stap 5, afbeelding 2 van 3 How to Reattach Loose Book Pages: stap 5, afbeelding 3 van 3
    • Place a rubber band around the book to hold it closed and to ensure pages are held in place.
    • Additionally, you can stack heavier books on top of your repaired book.
    • Let the book dry for 24 hours.
  6. How to Reattach Loose Book Pages: stap 6, afbeelding 1 van 2 How to Reattach Loose Book Pages: stap 6, afbeelding 2 van 2
    • Remove the heavy books and rubber band.
  7. How to Reattach Loose Book Pages: stap 7, afbeelding 1 van 1
    • Gently flip through your book. The pages should feel secure.
    • If the pages donโ€™t feel secure you can repeat steps 1 through 6.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Carrie
256 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Thank you , very useful . Be Lucky ๐Ÿ€ Glenn.
chuckle.tometoyou - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 340
Altijd: 22,349
