Onderdelen
Geen onderdelen nodig.
  1. Reinsert the screen into the case that contains the buttons.
    • Reinsert the screen into the case that contains the buttons.
  2. Put the Motherboard back into casing from right to left.
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors. Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard. Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
      • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. Connect the blue and red screen cables to the beige box they were removed from. Connect the blue and red screen cables to the beige box they were removed from.
    • Connect the blue and red screen cables to the beige box they were removed from.
  6. Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap. Insert the ZIF tab into the connector box.
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  7. Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  8. Place the front and back covers around the casing containing the motherboard and screen.
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  9. Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  10. Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Angela Arthur
101 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Buehl Winter 2012 Lid van Ohio State, Team 1-5, Buehl Winter 2012
OSU-BUEHL-W12S1G5
5 Leden
1 handleiding geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 140
