Inleiding
This repair guide's goal is to offer a set of steps to help you get your sliding closet door back on track.
This guide begins with cleaning out the tracks of your sliding closet door. Additionally it provides instructions to realign the sliding closet door with the top and bottom tracks.
Lastly, this guide offers a means of lubricating the tracks to promote smooth closet door sliding.
Wat je nodig hebt
Investigate the cleanliness of the tracks.
If the tracks are dirty, scrub them with toothbrush to clean out the dust.
You can use a rag or a hand vacuum to remove the loosened dust.
If the bottom rollers do not align, follow these steps:
Do not force anything.
Gently try to lift up on the door and guide its bottom rollers into the bottom tracks.
If the door still needs to be realigned, continue to Step 4.
If the door is successfully realigned with the bottom tracks, continue to Step 6.
The doors should be located properly on their tracks.
Try to slide the doors along the tracks.
If they don't slide well, you may need to lubricate the tracks:
Grab a lubricant: olive oil, fish oil, mineral oil, or petroleum jelly.
Apply a small amount of the lubricant to the edge of the rag.
Fit the edge of the rag into the tracks.
Spread the rag throughout the tracks to spread the lubricant.
Slide the closet door along the tracks to spread the lubricant further.
Thank you for considering this guide. To maintain properly working sliding closet doors, periodically clean and lubricate the tracks as described in this guide.
11 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Bonjour :)
Je suis très contente de vos explications accompagnées de photos !
Elles vont m'être très utiles pour, enfin, remettre en état mon placard coulissant ;)
Merci beaucoup ! Vous êtes géniale !
Claire.
Hi, so this was sorta useful for me but I still have another question. My door slides along the floor and doesn't have a bottom track. Any tips as to how I'd go about fixing it? Thanks
