Inleiding
If you have found that a zipper slider is not moving up and down or will not close any of the zipper teeth, it may be because the zipper has become unaligned. Over time, zipper teeth will not match up or become stuck, causing accessories such as backpacks and purses to become almost unusable. This guide will teach you how to re-align a zipper on a backpack with a needle, thread, and pliers. Although some background knowledge in basic sewing skills is recommended, we will briefly explain some sewing techniques. We will be show you how to fix a backpack that will not zip properly by re-aligning an uneven zipper without the use of a sewing machine.
Onderdelen
Geen onderdelen opgegeven.
Locate the section of zipper with the problem.
After putting the slider back on the zipper, sew the ends of the zipper to prevent the slider from sliding off.
Insert the needle through one side of the zipper fabric and pull until it stops at the knot.
Then, insert the needle through the other side of the zipper fabric and pull tightly until it seems secure.
Test your zipper to see if it is working properly.
13 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
noice tank u
