Inleiding
If your Apple Watch’s touchscreen is broken or doesn’t respond to touch, you can’t power it down using the slide-to-power-off controls. Instead, follow this guide to switch off your Apple Watch using the side button and digital crown. After turning off your watch, you can proceed with repairs.
Press and hold both the side button and digital crown simultaneously.
Continue holding while the Apple Watch reboots.
When you see the Apple logo, release the digital crown. Continue holding the side button.
When the Apple logo disappears, release the side button.
That’s all! With your Apple Watch safely powered down, you can proceed with repairs.
71 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Hi Jeff, is this supposed to work with series 3 watches. All I see is the time and a red lightning bolt which then disappears and then reappears
Readers,
If a red lightning bolt is on screen, it needs charged. When charging, it’ll turn green. Note: if watch is drained, it may be a bit before it’s green. If watch is blank or has an Apple Magnetic Charger and red bolt, leave it on for 30m. It should be green by then. If not, and using a Non-Apple “knock off” Charger, try an Apple Magnetic Watch Charger, Apple USB Adapter, and a working wall outlet (NOT a laptop or power bank). If it won't charge or reads “accessory isn't supported”, check for plastic films on either side of magnetic charge pad, and remove it. Clean the back of the watch and unplug and disconnect everything for about 10s. Then plug in and try to charge it. Both are magnetic and “stick” together. You should see the green bolt after some charge time. If not, then force restart (Jeff’s step 1) until Apple logo, then let go. No logo? Try another Apple Charger, Apple Adapter, and/or wall outlet. It’s $159 for a screen fix on a $200 watch. If all of this fails, better to just buy a new one.
Alice -
Ciao il mio Apple Watch ⌚️ non si spegne dal tasto laterale troppo duro o rigido come posso fare?
Thanks. It worked!
