Ga door naar hoofdinhoud
How to Perform a Hard Reset
Wat je nodig hebt
  1. How to Perform a Hard Reset, Face Plate: stap 1, afbeelding 1 van 1
    • Press the eject button on the bottom left corner of the face plate.
  2. How to Perform a Hard Reset: stap 2, afbeelding 1 van 3 How to Perform a Hard Reset: stap 2, afbeelding 2 van 3 How to Perform a Hard Reset: stap 2, afbeelding 3 van 3
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. How to Perform a Hard Reset, How to Perform a Hard Reset: stap 3, afbeelding 1 van 1
    • You will now have the face plate and the main component that includes the CD drive. Put the face plate aside and locate the small circle button labelled "Reset" on the main component.
    • Make sure the car power is on.
    • Press and hold the reset button with a pointed edge tool for 5 seconds.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Connor Finley
857 Reputatie
4 handleidingen geschreven
USF Tampa, Team S2-G5, Lacy Spring 2017 Lid van USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
4 Leden
11 handleidingen geschreven
Één opmerking
I have a Kenwood car stereo w4044ua and i put a code on it, will the code be removed when I reset ihe device
Defcon 1 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 108
Afgelopen 30 dagen: 433
Altijd: 61,842
