Ga door naar hoofdinhoud
How to Patch a Tear in Vinyl Furniture
Wat je nodig hebt
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: stap 1, afbeelding 1 van 1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: stap 2, afbeelding 1 van 1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: stap 3, afbeelding 1 van 2 How to Patch a Tear in Vinyl Furniture: stap 3, afbeelding 2 van 2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: stap 4, afbeelding 1 van 2 How to Patch a Tear in Vinyl Furniture: stap 4, afbeelding 2 van 2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: stap 5, afbeelding 1 van 1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: stap 6, afbeelding 1 van 2 How to Patch a Tear in Vinyl Furniture: stap 6, afbeelding 2 van 2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Conclusie
Once the adhesive is dry, the furniture is ready for use!
4 andere personen hebben deze handleiding voltooid.
Bailey Arman
188 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 302
Altijd: 24,562
