Ga door naar hoofdinhoud
How to Patch Large Holes in a Quilt
Wat je nodig hebt
  1. How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: stap 1, afbeelding 1 van 3 How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: stap 1, afbeelding 2 van 3 How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: stap 1, afbeelding 3 van 3
    • Carefully cut away damaged, torn, or frayed fabric.
    Vraag FixBot
    Voeg opmerking toe
  2. How to Patch Large Holes in a Quilt: stap 2, afbeelding 1 van 1
    • Measure the size of the hole. You will need to add a 1/2 inch to the width and length for seam allowance.
    • For example, if your hole is 5 inches by 5 inches your new fabric will measure 5.5 inches by 5.5 inches.
    Vraag FixBot
    Voeg opmerking toe
  3. How to Patch Large Holes in a Quilt: stap 3, afbeelding 1 van 2 How to Patch Large Holes in a Quilt: stap 3, afbeelding 2 van 2
    • Measure and cut out your batting. The batting will be the exact size of the hole.
    Vraag FixBot
    Voeg opmerking toe
  4. How to Patch Large Holes in a Quilt: stap 4, afbeelding 1 van 2 How to Patch Large Holes in a Quilt: stap 4, afbeelding 2 van 2
    • Measure and cut out your new fabric.
    • Remember to add your 1/2 inch for seam allowance.
    Vraag FixBot
    Voeg opmerking toe
  5. How to Patch Large Holes in a Quilt: stap 5, afbeelding 1 van 1
    • Fold the edges of the fabric over 1/4 inch. Press with an iron.
    • Work your way around until all sides of the fabric are pressed 1/4 inch.
    Vraag FixBot
    Voeg opmerking toe
  6. How to Patch Large Holes in a Quilt: stap 6, afbeelding 1 van 1
    • With the wrong side of the fabric facing up, lay the batting on top of the fabric. Make sure the edge of the batting and fabric align.
    Vraag FixBot
    Voeg opmerking toe
  7. How to Patch Large Holes in a Quilt: stap 7, afbeelding 1 van 1
    • Place the batting and fabric over the hole. The batting will be under the new fabric.
    Vraag FixBot
    Voeg opmerking toe
  8. How to Patch Large Holes in a Quilt: stap 8, afbeelding 1 van 2 How to Patch Large Holes in a Quilt: stap 8, afbeelding 2 van 2
    • Pin the fabric and batting into place on the quilt.
    Vraag FixBot
    Voeg opmerking toe
  9. How to Patch Large Holes in a Quilt: stap 9, afbeelding 1 van 2 How to Patch Large Holes in a Quilt: stap 9, afbeelding 2 van 2
    • Using a 1/4 seam, attach the patch by sewing along the edges.
    Vraag FixBot
    Voeg opmerking toe
  10. How to Patch Large Holes in a Quilt: stap 10, afbeelding 1 van 2 How to Patch Large Holes in a Quilt: stap 10, afbeelding 2 van 2
    • There are two options for quilting the fabric: freehand or decorative stitch. The goal is to top stitch the fabric in an even pattern so that it is extra secure. This adds to the longevity of the quilt.
    • Option 1: Freehand (pictured)- using chalk or a fabric pen, mark your fabric in an even pattern like cross-hatch or a grid. The second picture shows the cross-hatch pattern highlighted in red.
    • Next, sew along your marked pattern.
    • Option 2: Decorative stitch- many newer sewing machines can apply a decorative stitch. You may still need to mark a general pattern to follow.
    Vraag FixBot
    Voeg opmerking toe
  11. How to Patch Large Holes in a Quilt: stap 11, afbeelding 1 van 1
    • Following your pattern, top stitch over the patch.
    Vraag FixBot
    Voeg opmerking toe
  12. How to Patch Large Holes in a Quilt: stap 12, afbeelding 1 van 1
    • Trim excess threads.
    Vraag FixBot
    Voeg opmerking toe
  13. How to Patch Large Holes in a Quilt: stap 13, afbeelding 1 van 1
    • Admire your handiwork!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Congratulations! You have successfully patched a quilt! Your work will ensure your quilt will be used for decades to come.
Mariah A.
217 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 72
Altijd: 549
