Ga door naar hoofdinhoud
How to Open the SteelSeries Stratus Duo
Wat je nodig hebt
  1. How to Open the SteelSeries Stratus Duo, Remove the sticker: stap 1, afbeelding 1 van 2 How to Open the SteelSeries Stratus Duo, Remove the sticker: stap 1, afbeelding 2 van 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. How to Open the SteelSeries Stratus Duo, Unscrew the back cover: stap 2, afbeelding 1 van 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: stap 3, afbeelding 1 van 3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: stap 3, afbeelding 2 van 3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: stap 3, afbeelding 3 van 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: stap 4, afbeelding 1 van 3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: stap 4, afbeelding 2 van 3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: stap 4, afbeelding 3 van 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. How to Open the SteelSeries Stratus Duo: stap 5, afbeelding 1 van 2 How to Open the SteelSeries Stratus Duo: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: stap 6, afbeelding 1 van 3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: stap 6, afbeelding 2 van 3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: stap 6, afbeelding 3 van 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. How to Open the SteelSeries Stratus Duo, Remove the back cover assembly: stap 7, afbeelding 1 van 1
    • Remove the back cover assembly.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Adriana Zwink
58.863 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
21.918 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 43
Altijd: 2,298
