Ga door naar hoofdinhoud
How to Open the GuliKit KingKong 2 Pro
Wat je nodig hebt
  1. How to Open the GuliKit KingKong 2 Pro, Unfasten the back cover screws: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
    Vraag FixBot
  2. How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: stap 2, afbeelding 1 van 2 How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: stap 2, afbeelding 2 van 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
    Vraag FixBot
  3. How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: stap 3, afbeelding 1 van 2 How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: stap 3, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
    Vraag FixBot
  4. How to Open the GuliKit KingKong 2 Pro: stap 4, afbeelding 1 van 2 How to Open the GuliKit KingKong 2 Pro: stap 4, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
    Vraag FixBot
  5. How to Open the GuliKit KingKong 2 Pro, Remove the back cover: stap 5, afbeelding 1 van 2 How to Open the GuliKit KingKong 2 Pro, Remove the back cover: stap 5, afbeelding 2 van 2
    • Separate the back cover from the front assembly and remove it.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
258.804 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
25.805 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 108
Altijd: 8,238
