Ga door naar hoofdinhoud
How to Mend a Hole in a Cotton Blanket
Wat je nodig hebt
    1. How to Mend a Hole in a Cotton Blanket, How to Mend a Hole in a Cotton Blanket: stap 1, afbeelding 1 van 1
      • Find the hole in the blanket
      Vraag FixBot
      Voeg opmerking toe
    2. How to Mend a Hole in a Cotton Blanket: stap 2, afbeelding 1 van 1
      • Put the needle through the blanket, right below the hole picking up just a little bit of the fabric and do not pull the thread all the way through.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Mend a Hole in a Cotton Blanket: stap 3, afbeelding 1 van 2 How to Mend a Hole in a Cotton Blanket: stap 3, afbeelding 2 van 2
      • Repeat step 2 about 2 more times by inserting the needle through the same hole
      Vraag FixBot
      Voeg opmerking toe
    4. How to Mend a Hole in a Cotton Blanket: stap 4, afbeelding 1 van 1
      • On the last you pull, do not pull all the way for it creates a loop. Put your needle through the loop, pull the thread all the way and this creates a secure knot.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Mend a Hole in a Cotton Blanket: stap 5, afbeelding 1 van 3 How to Mend a Hole in a Cotton Blanket: stap 5, afbeelding 2 van 3 How to Mend a Hole in a Cotton Blanket: stap 5, afbeelding 3 van 3
      • Pick one side of the hole and go through to the other side while picking up fabric from the other side and pull our thread through all the way.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Mend a Hole in a Cotton Blanket: stap 6, afbeelding 1 van 1
      • Repeat step 5 going in an upward direction until you have reached the top of the hole.
      Vraag FixBot
      Voeg opmerking toe
    7. How to Mend a Hole in a Cotton Blanket: stap 7, afbeelding 1 van 1
      • The last thread you pull through, do not pull all the way but instead put your need through the loop it creates and create a secure knot. Repeat this step about 2-3 more times threading through the same hole to create an extra secure knot.
      Vraag FixBot
      Voeg opmerking toe
    8. How to Mend a Hole in a Cotton Blanket: stap 8, afbeelding 1 van 1
      • Snip off the thread and make sure the hole has been mended. You can clean it up by trimming any loose fabric.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Kiara Lee
157 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 234
Altijd: 8,235
