Ga door naar hoofdinhoud
How to Manually Eject a Stuck Disc in a PlayStation 5
Wat je nodig hebt
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: stap 1, afbeelding 1 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: stap 1, afbeelding 2 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: stap 1, afbeelding 3 van 3
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: stap 2, afbeelding 1 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5: stap 2, afbeelding 2 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5: stap 2, afbeelding 3 van 3
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: stap 3, afbeelding 1 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5: stap 3, afbeelding 2 van 3 How to Manually Eject a Stuck Disc in a PlayStation 5: stap 3, afbeelding 3 van 3
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: stap 4, afbeelding 1 van 2 How to Manually Eject a Stuck Disc in a PlayStation 5: stap 4, afbeelding 2 van 2
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jason Pinto
283 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 93
Afgelopen 30 dagen: 433
Altijd: 7,089
