Ga door naar hoofdinhoud
How to Make Jeans Fitted
Wat je nodig hebt
  1. How to Make Jeans Fitted, How to Make Jeans Fitted: stap 1, afbeelding 1 van 2 How to Make Jeans Fitted, How to Make Jeans Fitted: stap 1, afbeelding 2 van 2
    • Lay jeans out on a table.
    • Table must have enough space to lay out jeans.
  2. How to Make Jeans Fitted: stap 2, afbeelding 1 van 1
    • Flip jeans inside out.
  3. How to Make Jeans Fitted: stap 3, afbeelding 1 van 1
    • Identify the outer seam on both right and left sides.
  4. How to Make Jeans Fitted: stap 4, afbeelding 1 van 1
    • Put on the jeans inside out.
  5. How to Make Jeans Fitted: stap 5, afbeelding 1 van 2 How to Make Jeans Fitted: stap 5, afbeelding 2 van 2
    • Pin the amount of fabric you would like taken in on the outer sides. Mark where the pins are using a marker/pen.
    • Pins should be about an inch apart for an accurate measurement.
  6. How to Make Jeans Fitted: stap 6, afbeelding 1 van 2 How to Make Jeans Fitted: stap 6, afbeelding 2 van 2
    • Connect the dots to make a clear guide to cut off.
    • Double check if you are satisfied with the amount that will be taken off.
  7. How to Make Jeans Fitted: stap 7, afbeelding 1 van 2 How to Make Jeans Fitted: stap 7, afbeelding 2 van 2
    • Take a pair and scissors and cut along the guide (or markings) that you made on both sides.
    • When cutting your jeans it is always better to cut less as opposed to too much as you can always go back and make it smaller.
  8. How to Make Jeans Fitted: stap 8, afbeelding 1 van 1
    • Align edges, and make sure they are even before you start sewing.
  9. How to Make Jeans Fitted: stap 9, afbeelding 1 van 2 How to Make Jeans Fitted: stap 9, afbeelding 2 van 2
    • Hold the edges together and sew.
    • Sew the seam about 1/4-1/2 of an inch away from the edge. This will ensure that that the seam will not unravel if there is any fringe
    • Your stitches should be 1/2 cm in length or less to ensure a strong seam.
  10. How to Make Jeans Fitted: stap 10, afbeelding 1 van 2 How to Make Jeans Fitted: stap 10, afbeelding 2 van 2
    • Put on jeans, enjoy your new fit.
Conclusie
Your big jeans will now be fitted into your personal size.
Sophia Vo
195 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 1,044
