Ga door naar hoofdinhoud
LG G3 - How to fix GPS not working
Wat je nodig hebt
  1. LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: stap 1, afbeelding 1 van 3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: stap 1, afbeelding 2 van 3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: stap 1, afbeelding 3 van 3
    • Shutdown your phone.
    • Remove the back cover of the phone
    • Unscrew all the screws identified in red in the picture.
    • Remove the plastic covers using your fingernails or a plastic tool.
  2. LG G3 - How to fix GPS not working: stap 2, afbeelding 1 van 1
    • Carefully peel off the 3 metal stickers (connectors) identified in white on the photo with a flat screwdriver.
    • Please note these stickers are fragile and can tear.
    • Cut pieces of a sheet of cardboard or a sheet thick enough to the size of the stickers.
    • Glue a piece of cardboard or thick paper under each sticker to create extra thickness.
    • Replace the stickers in their original location (they will no longer stick to the shell, but that's okay).
    • Reassemble the phone by repeating the previous steps, taking care to tighten the screws properly when reassembling
Conclusie
To reassemble your device, follow the instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
draxx
175 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 1,915
