Inleiding
This guide shows how to install and remove the Tiles on your Framework Desktop.
The Tiles are mainly for decoration; they aren't necessary for your desktop to function.
The Front Panel can support up to 21 tiles.
Wat je nodig hebt
Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
Remove the Tile.
Lay a Tile over an open slot on your Front Panel.
Use your fingers to press the tile into the slot and engage the clips.
If you need help, contact Framework support.
