Ga door naar hoofdinhoud
How to Install LED License Plate Lights
Wat je nodig hebt
  1. How to Install LED License Plate Lights, Prep work: stap 1, afbeelding 1 van 1
    • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
  2. How to Install LED License Plate Lights, Removing the stock bulb: stap 2, afbeelding 1 van 3 How to Install LED License Plate Lights, Removing the stock bulb: stap 2, afbeelding 2 van 3 How to Install LED License Plate Lights, Removing the stock bulb: stap 2, afbeelding 3 van 3
    • Pull out the license plate lamp assembly and remove the stock license plate bulb.
  3. How to Install LED License Plate Lights, Installing the LED license plate bulb: stap 3, afbeelding 1 van 2 How to Install LED License Plate Lights, Installing the LED license plate bulb: stap 3, afbeelding 2 van 2
    • Install back the new LED license plate bulb.
    • Test to make sure the LED bulb works.
  4. How to Install LED License Plate Lights, Putting the license plate assembly back: stap 4, afbeelding 1 van 2 How to Install LED License Plate Lights, Putting the license plate assembly back: stap 4, afbeelding 2 van 2
    • Put the license plate assembly back and repeat on the other side.
  5. How to Install LED License Plate Lights, Enjoy: stap 5, afbeelding 1 van 1
    • Once everything works, you can enjoy your new LED license plate look.
Conclusie
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
5 andere personen hebben deze handleiding voltooid.
Eric Wu
3.267 Reputatie
23 handleidingen geschreven
Één opmerking
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 70
Altijd: 14,107
