Ga door naar hoofdinhoud
How to Install Handlebar Tape
Wat je nodig hebt
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: stap 1, afbeelding 1 van 2 How to Install Handlebar Tape, How to Install Handlebar Tape: stap 1, afbeelding 2 van 2
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: stap 2, afbeelding 1 van 3 How to Install Handlebar Tape: stap 2, afbeelding 2 van 3 How to Install Handlebar Tape: stap 2, afbeelding 3 van 3
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: stap 3, afbeelding 1 van 2 How to Install Handlebar Tape: stap 3, afbeelding 2 van 2
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: stap 4, afbeelding 1 van 2 How to Install Handlebar Tape: stap 4, afbeelding 2 van 2
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: stap 5, afbeelding 1 van 3 How to Install Handlebar Tape: stap 5, afbeelding 2 van 3 How to Install Handlebar Tape: stap 5, afbeelding 3 van 3
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: stap 6, afbeelding 1 van 3 How to Install Handlebar Tape: stap 6, afbeelding 2 van 3 How to Install Handlebar Tape: stap 6, afbeelding 3 van 3
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: stap 7, afbeelding 1 van 2 How to Install Handlebar Tape: stap 7, afbeelding 2 van 2
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: stap 8, afbeelding 1 van 2 How to Install Handlebar Tape: stap 8, afbeelding 2 van 2
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: stap 9, afbeelding 1 van 3 How to Install Handlebar Tape: stap 9, afbeelding 2 van 3 How to Install Handlebar Tape: stap 9, afbeelding 3 van 3
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: stap 10, afbeelding 1 van 1
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: stap 11, afbeelding 1 van 3 How to Install Handlebar Tape: stap 11, afbeelding 2 van 3 How to Install Handlebar Tape: stap 11, afbeelding 3 van 3
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: stap 12, afbeelding 1 van 3 How to Install Handlebar Tape: stap 12, afbeelding 2 van 3 How to Install Handlebar Tape: stap 12, afbeelding 3 van 3
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: stap 13, afbeelding 1 van 3 How to Install Handlebar Tape: stap 13, afbeelding 2 van 3 How to Install Handlebar Tape: stap 13, afbeelding 3 van 3
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Elizabeth Hall
131 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G7, Cole Spring 2017 Lid van UC Davis, Team S2-G7, Cole Spring 2017
UCD-COLE-S17S2G7
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 3,991
