Ga door naar hoofdinhoud
How to Hem a Dress
Wat je nodig hebt
  1. How to Hem a Dress, How to Hem a Dress: stap 1, afbeelding 1 van 2 How to Hem a Dress, How to Hem a Dress: stap 1, afbeelding 2 van 2
    • Begin with dress that is too long for the desired fit or style.
  2. How to Hem a Dress: stap 2, afbeelding 1 van 1
    • Lay the dress out flat, aligning the bottom seams.
    • Make sure any under layers are out of the way.
  3. How to Hem a Dress: stap 3, afbeelding 1 van 1
    • With a ruler, measure the amount you want the dress shortened.
    • After deciding, subtract 1" (25.4mm) from the seam allowance
    • (Ex: You want 3" (76.2mm) off, so you would measure 2'' (50.8mm) from the bottom of the fabric.)
  4. How to Hem a Dress: stap 4, afbeelding 1 van 1
    • Use chalk or pen to mark the measurement.
    • Make small dashed marks around the entire dress to ensure a consistent measurement.
  5. How to Hem a Dress: stap 5, afbeelding 1 van 1
    • Iron the dress flat.
  6. How to Hem a Dress: stap 6, afbeelding 1 van 1
    • Use scissors to cut vertically from the bottom seam to where you marked your measurement.
  7. How to Hem a Dress: stap 7, afbeelding 1 van 1
    • Then turn the scissors 90 degrees and begin cutting along the dashed lines you made in Step 4.
  8. How to Hem a Dress: stap 8, afbeelding 1 van 1
    • Then, again with the ruler and chalk measure 1/2'' (12.7 mm) from the raw edge of the fabric.
  9. How to Hem a Dress: stap 9, afbeelding 1 van 2 How to Hem a Dress: stap 9, afbeelding 2 van 2
    • Fold along the measurement you just made and iron it flat.
  10. How to Hem a Dress: stap 10, afbeelding 1 van 2 How to Hem a Dress: stap 10, afbeelding 2 van 2
    • Then fold again, one more time at 1/2''.
    • Lastly iron flat.
  11. How to Hem a Dress: stap 11, afbeelding 1 van 2 How to Hem a Dress: stap 11, afbeelding 2 van 2
    • Pin the fold in place.
    • Be careful when you pin.
  12. How to Hem a Dress: stap 12, afbeelding 1 van 1
    • If using a sewing machine, place it under the foot of the sewing machine.
    • Sew around the entire circumference of the dress.
    • Be careful when using a sewing machine.
  13. How to Hem a Dress: stap 13, afbeelding 1 van 3 How to Hem a Dress: stap 13, afbeelding 2 van 3 How to Hem a Dress: stap 13, afbeelding 3 van 3
    • Cut the threads and you're done!
Conclusie
Juliette Price
217 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-5, Andersen Winter 2024 Lid van UC Davis, Team 3-5, Andersen Winter 2024
UCD-ANDERSEN-W24S3G5
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 109
