Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
A wild Epson Printer appears.
Turn it around and look for a small door.
Locate the small door on the back and open it.
You will find the tube that drains the waste ink to the ink pad.
As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
With a pair of tweezers gently pull the ink tube from the ink container.
Gereedschap gebruikt in deze stap:Desoldering Pump$3.99-
With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
Cut a 6" piece of the aquarium tubing and grab a connector.
Connect the printer tube to the aquarium tubing you just cut with the connector.
Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
17 andere personen hebben deze handleiding voltooid.
13 opmerkingen
I have the same problem. I will try that step. Good instructions. Thank you.
Thanks for this! =) God bless!
i need the ressetter for an epson l310
will this work on L220?
anyone have try this?
