Ga door naar hoofdinhoud
How to Hack Epson L200's Waste Ink Pad
Wat je nodig hebt
  1. How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: stap 1, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: stap 1, afbeelding 2 van 2
    • A wild Epson Printer appears.
    • Turn it around and look for a small door.
  2. How to Hack Epson L200's Waste Ink Pad: stap 2, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 2, afbeelding 2 van 2
    • Locate the small door on the back and open it.
    • You will find the tube that drains the waste ink to the ink pad.
  3. How to Hack Epson L200's Waste Ink Pad: stap 3, afbeelding 1 van 1
    • As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
  4. How to Hack Epson L200's Waste Ink Pad: stap 4, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • With a pair of tweezers gently pull the ink tube from the ink container.
    • Be careful not to grab it from the tube so as not to damage it.
  5. How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 1 van 3 How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 2 van 3 How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 3 van 3
    Desoldering Pump
    $3.99
    • With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
    • I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
    • I did not have a syringe at the time and used a desolder pump, takes way longer though.
  6. How to Hack Epson L200's Waste Ink Pad: stap 6, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 6, afbeelding 2 van 2
    • Cut a 6" piece of the aquarium tubing and grab a connector.
    • Connect the printer tube to the aquarium tubing you just cut with the connector.
  7. How to Hack Epson L200's Waste Ink Pad: stap 7, afbeelding 1 van 1
    • Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
    • I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
  8. How to Hack Epson L200's Waste Ink Pad: stap 8, afbeelding 1 van 1
    • I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
    • Check periodically to empty the waste ink bottle.
    Great idea. You are very smart)))
    Anar Farzaliyev - Antwoord
Conclusie
17 andere personen hebben deze handleiding voltooid.
Angela Penaherrera
12.604 Reputatie
5 handleidingen geschreven
13 opmerkingen
I have the same problem. I will try that step. Good instructions. Thank you.
Adi Priyono - Antwoord
Thanks for this! =) God bless!
CHRISTOPHER L. BIRUNG - Antwoord
i need the ressetter for an epson l310
thandolwenkosim - Antwoord
will this work on L220?
Andi Lesmana - Antwoord
anyone have try this?
eufrasiaaa - Antwoord
thank you very much it really helped me
Rupesh Gupta - Antwoord
Thank you for your guide
rsahirani - Antwoord
Epson l200 resetter adjustment software is a program to reset the waste ink pad counter on your printer. <a href="https://epsonadjprog.blogspot.com/2019/0... ">Epson L200 resetter</a> thank you
Priya Palukavali - Antwoord
The printer shall still generate waste ink counter (wic) how to reset the counter without buying the reset code.
bal_pk - Antwoord
you can use this waste ink to black tank again
Bikramdeep Singh - Antwoord
That was the easy part. The problem part is that the printer is keeping count of how many cleaning flushes it does, and at a certain number will stop printing until you either get a new one or reset the counter.
Keith Odom - Antwoord
Did you notice that I included information on your comment in the guide description? Other users also replied with information on how to reset the count. Hope that helps!
Angela Penaherrera -
Very Nice Thank you
srisrielango - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 139
Altijd: 55,689
