Ga door naar hoofdinhoud
How to Force Restart an iPhone 6s
  1. How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: stap 1, afbeelding 1 van 2 How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: stap 1, afbeelding 2 van 2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 6s: stap 2, afbeelding 1 van 2 How to Force Restart an iPhone 6s: stap 2, afbeelding 2 van 2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do u do then it gust goes black and won't turn on
    Angelina Walker - Antwoord
    Another question. What to do when these force start instructions result in a dead black, unchanged screen?
    csrmclaughlin - Antwoord
    So I’ve replaced the screen but still have just a blank black screen, when I try turning it on it has the plug in and charge icon pops up, and goes off when I unplug, but nothin else will display on screen!!! HELPPPP!! PLEASE!!
    Marc Andriani - Antwoord
Eindstreep
276 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.472 Reputatie
168 handleidingen geschreven
22 opmerkingen
Thank you! Thank you! This tip saved my day!
pamathis - Antwoord
I dropped my phone in the garage it locked my screen when I turn it on it has lines across real colorful but locked I m not able to retrieve contacts or photos from it…is there any hope,? I had to purchase another phone same one iPhone 6s I really need my contacts and photos from this phone?
atina1951 - Antwoord
my home button doesnt work, how do i do this without the home button?
Kennedy Truong - Antwoord
its not  working for me I been trying it and just did again any other suggestions when u have no ride
Amanda Wright - Antwoord
Swollen battery kept the home button from properly working on my phone, it spread the case apart slightly. Do you have battery problems?
Eric Andersen -
If the home button was malfunction, how to force restart?
Tseng Stanley - Antwoord
Brillant guide. Was my first time opening up an iPhone for repair. Guess what? It even works afterwards, which, I have to admit, is rarely the case when I try to fix something. Thanks
Karsten Fischer - Antwoord
Kit fit great. Be patient when installing. Would recommend
Danny Mosley - Antwoord
i did this with my phone and a bunch of grey lines appeared and then it went completely black and no logo came up?
haileyfarlow123 - Antwoord
It doesn't work
Vikas Wahi - Antwoord
It is just off, it doesn’t do anything, even I left it hooked for the hole day and it won’t even show the battery when charging. Is there any way to full reset? I do not even care anymore for what I have, I just want my phone back.
ronster65 - Antwoord
what if the homebutton does not work? Is there a way to restart then?
Sharon Held - Antwoord
i got so incredibly lucky. i actually misplaced two of the screws belonging to the panel that holds down the 3 display connector cables, saying “&&^& it” and only using the two at my disposal. fearing having to buy a new phone (having completed all the steps), i forced a restart and… it works perfectly. no common issues that i had seen in any of these comments. thanks so much!!
Jack Larson - Antwoord
Well done guide. Thanks.
Leon - Antwoord
et quoi faire si mon bouton home ne marche plus ?
Sara Bjd - Antwoord
Amazing trick! Last thing I needed was to get a new phone right now.
jgensib - Antwoord
on/off bottom on right hand side does not work after battery change
is there any possibility to make a hard reset?
on my mcbook in finder it is not possible
Kai Gundrum - Antwoord
Se queda la manzana a reiniciarlo y de ahi no pasa😢😢
Alejandro piña - Antwoord
솔직히 최신형 홈버튼 없는 iPhone이 강제 재시동은 편할 것 같네요..
Turtle - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 45
Afgelopen 7 dagen: 277
Afgelopen 30 dagen: 1,116
Altijd: 275,212
