Ga door naar hoofdinhoud
How to Force Restart an iPhone 4S
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: stap 1, afbeelding 1 van 2 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: stap 1, afbeelding 2 van 2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
    Helpful.......it's working. PTL!!!! It's saved.
    Renee A Watson - Antwoord
    i cant use my power button because it cant function
    Elsa Cagampang - Antwoord
    please help me.. how can i restart my phone using emergency call beacause the power button of my cp it cannot function.
    Its not workiing because the home button of my phone is malfunctioned
    Niranjan Manoj - Antwoord
  2. How to Force Restart an iPhone 4S: stap 2, afbeelding 1 van 2 How to Force Restart an iPhone 4S: stap 2, afbeelding 2 van 2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do you do if the apple doesn’t appear?
    David Wilmot - Antwoord
Eindstreep
233 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.466 Reputatie
168 handleidingen geschreven
23 opmerkingen
what if our power butoon is broken/
Autumn Harris - Antwoord
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers -
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - Antwoord
Great Instructions! Thank you.
georgiaruocco - Antwoord
bravo c superbe
perdereau - Antwoord
my iphone is not getting started. it turns on when i plug in the cable but still stucks in the iphone logo.
Tarif Hasan - Antwoord
Thank you Heather Powers! You must be one of the geniuses ;p
Susanne Vierbergen - Antwoord
Thank you so much my phone is now working it has been off, the past 4 days but its now finally working 100% :-)
Asia Kakorokoro - Antwoord
not helpful whatso ever dont listen to him he is a lieer
thomas andrews - Antwoord
soz he dosent reall suck and lie
can anyone help me my iphone wont go to the main home screen i turn my phone on and its shows itunes symbol and charger how do i removve that
Dawn Henry - Antwoord
Thank you it brot my iphone 4S back, great
genebrn - Antwoord
My home button is broken.
Ruby Magdalene Acol-Acol - Antwoord
Please tell me what comes next. I get logo then what do I do
Billie kennedy - Antwoord
you just wait until your homescreen appears :3
YTKatten -
Works fine. Online instructions are well illustrated, but it would be helpful to WARN potential users that the little screws holding the battery clip are really tough to orient and re-insert. Be sure to work on a clean white surface; so, if they fall off the driver they don’t wind up on the floor. You’ll never find them there. I was lucky, they stuck to the magnetic tool that came with the kit.
Robert Vrijenhoek - Antwoord
IT all went smoothly for me, but my own unsteady hand was my worst enemy (I am 65+), and a constant fear that I would drop one of those nearly invisible screws on the carpet below.
Gary Liebisch - Antwoord
i didnt put the display in the perfect way in the phone, had to reopen it again, but put too much pressure onto it and i think i killed some cable?
its not doing anything again so..
is there anything i can do?
maximmerle - Antwoord
Merhaba , iPhone 4s şarja takıldığında apple logosu geliyor biraz durup sonra gidiyor böyle döngü ediyor ve telefon açılmıyor
oyun ustası 2004.2005 - Antwoord
Çözüm nedir acaba?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 198
Altijd: 84,634
