Ga door naar hoofdinhoud
How to Flatten a Folded Poster
Wat je nodig hebt
  1. How to Flatten a Folded Poster, How to Flatten a Folded Poster: stap 1, afbeelding 1 van 2 How to Flatten a Folded Poster, How to Flatten a Folded Poster: stap 1, afbeelding 2 van 2
    • Open up the poster on a flat and clean surface and turn it over.
  2. How to Flatten a Folded Poster: stap 2, afbeelding 1 van 3 How to Flatten a Folded Poster: stap 2, afbeelding 2 van 3 How to Flatten a Folded Poster: stap 2, afbeelding 3 van 3
    • Wet a paper towel and wring most of the water out.
  3. How to Flatten a Folded Poster: stap 3, afbeelding 1 van 2 How to Flatten a Folded Poster: stap 3, afbeelding 2 van 2
    • Fold the damp paper towel and use it to lightly moisten the folds.
    • Doing this relaxes the fibers in the paper.
  4. How to Flatten a Folded Poster: stap 4, afbeelding 1 van 2 How to Flatten a Folded Poster: stap 4, afbeelding 2 van 2
    • Turn on the iron, and switch it to the warm mode or the lowest temperature.
    • Make sure to not use the vapor or steam settings.
  5. How to Flatten a Folded Poster: stap 5, afbeelding 1 van 2 How to Flatten a Folded Poster: stap 5, afbeelding 2 van 2
    • While the iron is warming up, take out any medium to use as an interleaving sheet.
    • The medium for the interleaving sheet can be a piece of cloth/paper/tissue/towel...etc.
    • Don’t put your iron in direct contact with the poster.
  6. How to Flatten a Folded Poster: stap 6, afbeelding 1 van 2 How to Flatten a Folded Poster: stap 6, afbeelding 2 van 2
    • Put the interleaving sheet of your choice on the folds, and move the iron across the sheet and poster gently as you work on all the folds.
    • Repeat on the other side as necessary.
  7. How to Flatten a Folded Poster: stap 7, afbeelding 1 van 2 How to Flatten a Folded Poster: stap 7, afbeelding 2 van 2
    • The End! You get a flat poster now!
    • After this treatment, the poster will become very flat and most of the creases can be removed. But some physical damage brought by folding may be difficult to be completely erased.
Conclusie
Manshu Liu
145 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-5, Andersen Winter 2023 Lid van UC Davis, Team 1-5, Andersen Winter 2023
UCD-ANDERSEN-W23S1G5
2 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 130
Afgelopen 30 dagen: 644
Altijd: 5,829
