Ga door naar hoofdinhoud
How to Fix/Prevent Joystick Drift on a DualShock 3
Wat je nodig hebt
  1. How to Fix/Prevent Joystick Drift on a DualShock 3, How to Fix/Prevent Joystick Drift on a DualShock 3: stap 1, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm Phillips screws which hold the back shell to the controller.
  2. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 2, afbeelding 1 van 1
    • Remove the back shell from the controller by pulling the front and back shells apart at the same time.
  3. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 3, afbeelding 1 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 3, afbeelding 2 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 3, afbeelding 3 van 3
    • Disconnect the battery from the controller by pressing the two sides of the connector and pulling it out.
    • Do not pull on the red and black wires to avoid damaging the connection.
  4. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 4, afbeelding 1 van 2 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 4, afbeelding 2 van 2
    • Use a toothpick to remove any sticky dirt like substances from the rumble motors.
    • Use the cotton swab to remove any dust particles or hairs from the rumble motors.
  5. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 5, afbeelding 1 van 2 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 5, afbeelding 2 van 2
    • Remove the motherboard by pushing the two white hooks on both the left and right side of the motherboard backwards.
  6. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw, which secures the white body piece inside the controller.
  7. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 7, afbeelding 1 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 7, afbeelding 2 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 7, afbeelding 3 van 3
    • To remove the white body piece, start by using your fingers to unhook the small black hooks securing the left and right rumble motors.
  8. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 8, afbeelding 1 van 2 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 8, afbeelding 2 van 2
    • Remove the white body piece from the controller by pushing the unhooked left and right rumble motors in an upward direction.
  9. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 9, afbeelding 1 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 9, afbeelding 2 van 3 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 9, afbeelding 3 van 3
    • Use the brush to remove dust/dirt particles from the inside of the front shell.
    • Use a cotton swab to remove any dust/dirt particles in smaller crevices.
  10. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 10, afbeelding 1 van 2 How to Fix/Prevent Joystick Drift on a DualShock 3: stap 10, afbeelding 2 van 2
    • Reattach the white body piece to the inside of the front shell by pushing the rumble motors back in place.
    • The rumble motors are properly secured when you can see that the small black hooks are holding them firmly in place.
  11. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 11, afbeelding 1 van 1
    • Place the battery back onto the motherboard.
    • Reconnect the battery by plugging the white connector piece back into the beige colored socket.
  12. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 12, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to screw the single 7.2 mm Phillips screw to secure the white body piece inside the controller.
  13. How to Fix/Prevent Joystick Drift on a DualShock 3: stap 13, afbeelding 1 van 1
    • Snap the front and back shell together.
    • Screw the five 7.2 mm Phillips screws on the back shell screw holders, using the Phillips #1 screwdriver.
Conclusie
If this maintenance did not fix your joystick drift, you may need to replace the joysticks altogether.
9 andere personen hebben deze handleiding voltooid.
Rohan Bangash
487 Reputatie
1 Handleiding geschreven
York University, Team M-1, Allen Summer 2022 Lid van York University, Team M-1, Allen Summer 2022
YORK-ALLEN-SU22SMG1
1 Lid
5 handleidingen geschreven
Één opmerking
This guide is very helpful to all the users of PS3 as this is commonly occurring problem in the gaming console controller. This quick fix can save people a lot of money from not sending controller to PS service station for repair. I really liked how detailed each step is described with proper instruction and to the point. The tools you used liked toothpicks and cotton swaps, are also some of the things which are easily available at everyone's house and there's no special need to go to market for it, which makes the fix much more easier.
Prarthit patel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 229
Afgelopen 30 dagen: 889
Altijd: 19,440
