Ga door naar hoofdinhoud
How to Fix the Side Pocket's Elastic on a Backpack
Wat je nodig hebt
    1. How to Fix the Side Pocket's Elastic on a Backpack, How to Fix the Side Pocket's Elastic on a Backpack: stap 1, afbeelding 1 van 1
      • Trim any excess thread and frayed edges from the fabric with your scissors.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Fix the Side Pocket's Elastic on a Backpack: stap 2, afbeelding 1 van 1
      • Stretch the elastic to match in length with the fabric.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Fix the Side Pocket's Elastic on a Backpack: stap 3, afbeelding 1 van 1
      • Tuck the fabric edge back into the elastic.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Fix the Side Pocket's Elastic on a Backpack: stap 4, afbeelding 1 van 1
      • Pin the fabric and elastic together.
      • Working with needles and pins can be dangerous.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Fix the Side Pocket's Elastic on a Backpack: stap 5, afbeelding 1 van 1
      • Begin stitching the fabric and elastic together.
      • Start about one centimeter before the tear begins.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Fix the Side Pocket's Elastic on a Backpack: stap 6, afbeelding 1 van 1
      • Continue stitching and remove pins when you sew past the part they're holding together.
      Vraag FixBot
      Voeg opmerking toe
    7. How to Fix the Side Pocket's Elastic on a Backpack: stap 7, afbeelding 1 van 1
      • Stitch until you have passed the end of the tear by about a centimeter.
      Vraag FixBot
      Voeg opmerking toe
    8. How to Fix the Side Pocket's Elastic on a Backpack: stap 8, afbeelding 1 van 1
      • End the stitch by tying a small knot close to where the thread passes through the fabric.
      Vraag FixBot
      Voeg opmerking toe
    9. How to Fix the Side Pocket's Elastic on a Backpack: stap 9, afbeelding 1 van 1
      • Cut the thread just above the knot so there is little excess.
      Vraag FixBot
      Voeg opmerking toe
    10. How to Fix the Side Pocket's Elastic on a Backpack: stap 10, afbeelding 1 van 1
      • Clean your work space and put away the tools
      • Congratulations, you're done!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emily Burnside
155 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-6, Green Fall 2015 Lid van Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 267
Altijd: 10,336
