Ga door naar hoofdinhoud
How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X
Wat je nodig hebt
  1. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 1, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 1, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X, How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 1, afbeelding 3 van 3
    • Turn the Sorrento Grey Loveseat over.
  2. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 2, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 2, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 2, afbeelding 3 van 3
    • Remove the snap cover that is covering the back to show the seat's sliding mechanism.
  3. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 3, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 3, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 3, afbeelding 3 van 3
    • Pull off the seat connected to its base by pulling the clamps on both sides outward and the seat towards your body.
  4. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 4, afbeelding 1 van 2 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 4, afbeelding 2 van 2
    • Align the hole of the sliding mechanism to hole on the wood of the seat.
  5. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 5, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 5, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 5, afbeelding 3 van 3
    • Insert a screw into the hole and secure a bolt on the end.
  6. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 6, afbeelding 1 van 1
    • Use a drill and vice grips to secure the bolt on the screw.
  7. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 7, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 7, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 7, afbeelding 3 van 3
    • Attach the seat back onto the loveseat.
  8. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 8, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 8, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 8, afbeelding 3 van 3
    • Use force to lock the seat into place.
  9. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 9, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 9, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 9, afbeelding 3 van 3
    • Cover the sliding mechanisms with the snap cover.
  10. How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 10, afbeelding 1 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 10, afbeelding 2 van 3 How to Fix the Seat on a Sorrento Grey Loveseat 59928-028-1X: stap 10, afbeelding 3 van 3
    • Guide and place the loveseat back into upright position.
Conclusie
Shaquan Mayes
181 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 326
