Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Return-to-home functionality failure is a common issue of iPhone 7/7P and the problem is usually related to the U10 chip on the home button cable.
Video overzicht
  1. Open an APP and then press the home button, it fails to return back to the home screen. Double-press the home button and there is also no response. Long-press the home button and Siri is also not launched.
    • Open an APP and then press the home button, it fails to return back to the home screen. Double-press the home button and there is also no response. Long-press the home button and Siri is also not launched.
    • However, Touch ID can be set up successfully.
  2. The return-to-home functionality of home buttons on iPhone 7/7P/8/8P is supported by the U10 chip on the home button cable. Let’s try to replace with a new U10 chip and see how it works.
    • The return-to-home functionality of home buttons on iPhone 7/7P/8/8P is supported by the U10 chip on the home button cable. Let’s try to replace with a new U10 chip and see how it works.
  3. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Secure the cable with High-temperature tape. Heat with the Hot Air Gun to remove sealing adhesive around U10 chip. Then detach the U10 chip from the home button cable.
    • Secure the cable with High-temperature tape. Heat with the Hot Air Gun to remove sealing adhesive around U10 chip. Then detach the U10 chip from the home button cable.
  5. Solder a new U10 chip. Get the home button cable installed.
    • Solder a new U10 chip. Get the home button cable installed.
    • Turn on the phone and test. Touch ID works normally. The return-to-home functionality is also back to normal.
    • Follow this video guide to fix iPhone 7/7P home button not working issue.
    • Touch ID of the phone works normally while return-to-home functionality fails.
    • Credit: REWA Technology
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Phryne
1.736 Reputatie
16 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 155
Altijd: 305
