Inleiding
If your Manual Recliner Hydraulic Barber chair has issues with the balance, use this guide to assess and repair the problem.
The problem with an unbalanced hydraulic chair tends to be an issue with the base of the chair, usually due to missing or damaged screws.
This guide is simple enough that anyone with no experience in repair will be able to follow through to the end and achieve the result they wish.
Before beginning, make sure that you have another person to lend a hand as the seat of the chair might be too heavy for one person.
Wat je nodig hebt
The issue with the barber chair is located at the base, where the screws have come loose.
