Ga door naar hoofdinhoud
How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer
Wat je nodig hebt
  1. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 1, afbeelding 1 van 2 How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 1, afbeelding 2 van 2
    • Unscrew the leveling wheels under the bed and remove the print bed from its brackets.
  2. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 2, afbeelding 1 van 1
    • Use the 6 mm open-end wrench to hold the bottom of the bolt connections that are not in contact with the railing, then loosen the bolts with a 3 mm hex key.
    • Do not remove the bolts, as this could move the bolt connection further from the railing.
  3. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 3, afbeelding 1 van 1
    • Orient the eccentric nut with the 10 mm open-end wrench, turning it until the wheel bearing is in contact with the rail.
  4. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 4, afbeelding 1 van 1
    • Hold the bottom of the loosened bolt-connection with the 6 mm open-end wrench, then refasten the bolt with a 3 mm hex key.
    • Do not overtighten the bolt connection as this could strip the screw head.
  5. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 5, afbeelding 1 van 1
    • Test the wheel bearing for slippage, using your fingers to attempt to turn the wheel bearing.
    • If slippage remains persistent, repeat steps 2-5 until the wheel bearing does not slip on the rail guide when tested.
  6. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 6, afbeelding 1 van 2 How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: stap 6, afbeelding 2 van 2
    • Place the print bed back over its bracket, refastening it with the leveling wheels.
Conclusie
Your y-axis should now be secured without the worry of misprinted layers. Happy printing!
6 andere personen hebben deze handleiding voltooid.
Max Rathburn
277 Reputatie
1 Handleiding geschreven
Één opmerking
Just want to say this is by far the most helpful of all how to articles I saw to address this issue. Thank you
John Harris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 162
Altijd: 10,075
