Ga door naar hoofdinhoud
How to Fix a Whirlpool WDF330PAHW Door Latch
Wat je nodig hebt
  1. How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: stap 1, afbeelding 1 van 2 How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: stap 1, afbeelding 2 van 2
    • Open the dishwasher door and look for the retaining screws around the side edge and top edge of the dishwasher door.
  2. How to Fix a Whirlpool WDF330PAHW Door Latch: stap 2, afbeelding 1 van 1
    • Using a T8 Torx screwdriver remove the two screws by turning counter clockwise.
  3. How to Fix a Whirlpool WDF330PAHW Door Latch: stap 3, afbeelding 1 van 2 How to Fix a Whirlpool WDF330PAHW Door Latch: stap 3, afbeelding 2 van 2
    • Lift the inner panel enough that you can loosen the two securing bolts on the door latch with the wrench.
    • When loosening the two bolts, leave them in and don't remove them.
  4. How to Fix a Whirlpool WDF330PAHW Door Latch: stap 4, afbeelding 1 van 2 How to Fix a Whirlpool WDF330PAHW Door Latch: stap 4, afbeelding 2 van 2
    • Carefully raise the dishwasher door to align the door latch with the strike plate.
    • Watch fingers while raising dishwasher door.
  5. How to Fix a Whirlpool WDF330PAHW Door Latch: stap 5, afbeelding 1 van 1
    • Hold the door latch with your finger tips to align the door latch.
    • Then lower the door and tighten the door latch securing bolts.
  6. How to Fix a Whirlpool WDF330PAHW Door Latch: stap 6, afbeelding 1 van 1
    • Install the inner door panel retaining screws.
    • Proceed to tighten two screws with the T8 Torx screwdriver.
    • When tightening the two screws turn clockwise.
    • Then close the dishwasher door.
Eindstreep
Magdalene Cannon
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 51
Altijd: 2,735
