Ga door naar hoofdinhoud
How to Fix a Tear in a Jacket Lining
Wat je nodig hebt
  1. How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: stap 1, afbeelding 1 van 3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: stap 1, afbeelding 2 van 3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: stap 1, afbeelding 3 van 3
    • Turn the jacket inside out.
  2. How to Fix a Tear in a Jacket Lining: stap 2, afbeelding 1 van 2 How to Fix a Tear in a Jacket Lining: stap 2, afbeelding 2 van 2
    • Put the thread through the needle hole.
    • Use thread that is the same color as the material you are sewing.
  3. How to Fix a Tear in a Jacket Lining: stap 3, afbeelding 1 van 3 How to Fix a Tear in a Jacket Lining: stap 3, afbeelding 2 van 3 How to Fix a Tear in a Jacket Lining: stap 3, afbeelding 3 van 3
    • Take the two ends of the thread and knot them together.
  4. How to Fix a Tear in a Jacket Lining: stap 4, afbeelding 1 van 2 How to Fix a Tear in a Jacket Lining: stap 4, afbeelding 2 van 2
    • Cut the excess thread off.
  5. How to Fix a Tear in a Jacket Lining: stap 5, afbeelding 1 van 3 How to Fix a Tear in a Jacket Lining: stap 5, afbeelding 2 van 3 How to Fix a Tear in a Jacket Lining: stap 5, afbeelding 3 van 3
    • Push the needle through the fabric and pull it between the two threads to create a knot.
    • This prevents the thread from sliding through the fabric as you are sewing.
  6. How to Fix a Tear in a Jacket Lining: stap 6, afbeelding 1 van 3 How to Fix a Tear in a Jacket Lining: stap 6, afbeelding 2 van 3 How to Fix a Tear in a Jacket Lining: stap 6, afbeelding 3 van 3
    • Place one stitch on one side then place another one on the other side of the fabric.
    • Make sure the stitches are parallel and evenly distributed or the seams will not look straight.
    • Repeat this process until you have stitched down the length of the tear.
  7. How to Fix a Tear in a Jacket Lining: stap 7, afbeelding 1 van 2 How to Fix a Tear in a Jacket Lining: stap 7, afbeelding 2 van 2
    • Pull the thread through.
  8. How to Fix a Tear in a Jacket Lining: stap 8, afbeelding 1 van 3 How to Fix a Tear in a Jacket Lining: stap 8, afbeelding 2 van 3 How to Fix a Tear in a Jacket Lining: stap 8, afbeelding 3 van 3
    • Close the stitch.
  9. How to Fix a Tear in a Jacket Lining: stap 9, afbeelding 1 van 2 How to Fix a Tear in a Jacket Lining: stap 9, afbeelding 2 van 2
    • Cut off the excess thread off after securing the stitch.
  10. How to Fix a Tear in a Jacket Lining: stap 10, afbeelding 1 van 2 How to Fix a Tear in a Jacket Lining: stap 10, afbeelding 2 van 2
    • This is the final product.
Conclusie
If you mess up on a stitch, you can always cut and pull it out and start all over again.
4 andere personen hebben deze handleiding voltooid.
Electra Pyatt
253 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 113
Altijd: 8,050
