Ga door naar hoofdinhoud
How to Fix a T-shirt That's Too Big
Wat je nodig hebt
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: stap 1, afbeelding 1 van 2 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: stap 1, afbeelding 2 van 2
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: stap 2, afbeelding 1 van 1
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: stap 3, afbeelding 1 van 1
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: stap 4, afbeelding 1 van 1
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: stap 5, afbeelding 1 van 1
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: stap 6, afbeelding 1 van 1
    • Use scissors to cut any extra threads left over from the project.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
lakshay
185 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 48
Altijd: 1,602
