Ga door naar hoofdinhoud
How to Fix a Sticking Deadbolt
Wat je nodig hebt
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: stap 1, afbeelding 1 van 2 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: stap 2, afbeelding 1 van 2 How to Fix a Sticking Deadbolt: stap 2, afbeelding 2 van 2
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: stap 3, afbeelding 1 van 1
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: stap 4, afbeelding 1 van 2 How to Fix a Sticking Deadbolt: stap 4, afbeelding 2 van 2
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: stap 5, afbeelding 1 van 1
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: stap 6, afbeelding 1 van 2 How to Fix a Sticking Deadbolt: stap 6, afbeelding 2 van 2
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: stap 7, afbeelding 1 van 2 How to Fix a Sticking Deadbolt: stap 7, afbeelding 2 van 2
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: stap 8, afbeelding 1 van 1
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: stap 9, afbeelding 1 van 3 How to Fix a Sticking Deadbolt: stap 9, afbeelding 2 van 3 How to Fix a Sticking Deadbolt: stap 9, afbeelding 3 van 3
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: stap 10, afbeelding 1 van 1
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Conclusie
After following this fast fix guide, the sticking deadbolt should be fixed.
5 andere personen hebben deze handleiding voltooid.
Elizabeth Nesler
214 Reputatie
1 Handleiding geschreven
Texas Tech, Team 22-5, Rauch Spring 2016 Lid van Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 Leden
1 handleiding geschreven
Één opmerking
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 134
Altijd: 39,125
