Ga door naar hoofdinhoud
How to Fix a Squeaky Door Hinge
Wat je nodig hebt
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: stap 1, afbeelding 1 van 1
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: stap 2, afbeelding 1 van 1
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: stap 3, afbeelding 1 van 1
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: stap 4, afbeelding 1 van 1
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: stap 5, afbeelding 1 van 1
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: stap 7, afbeelding 1 van 1
    • Use a towel to catch any drips of oil and to wipe off the hinge.
Conclusie
The door should now be quite silent when opening and closing. Thank you for reading.
3 andere personen hebben deze handleiding voltooid.
Jake Herson
219 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 1-10, Lauer Spring 2016 Lid van Michigan Tech, Team 1-10, Lauer Spring 2016
MTU-LAUER-S16S1G10
1 Lid
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 84
Afgelopen 30 dagen: 267
Altijd: 4,190
