Ga door naar hoofdinhoud
How to Fix a Skewed Wheel on a Children's Kick Scooter
Wat je nodig hebt
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 1, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 1, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 1, afbeelding 3 van 3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 2, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 2, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 2, afbeelding 3 van 3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 3, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 3, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 3, afbeelding 3 van 3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 4, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 4, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 4, afbeelding 3 van 3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 5, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 5, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 5, afbeelding 3 van 3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 6, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 6, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 6, afbeelding 3 van 3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 7, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 7, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 7, afbeelding 3 van 3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 8, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 8, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 8, afbeelding 3 van 3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 9, afbeelding 1 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 9, afbeelding 2 van 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: stap 9, afbeelding 3 van 3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Eindstreep
Amir Issagali
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 1,450
