Ga door naar hoofdinhoud
How to Fix a Misaligned Desk Drawer
Wat je nodig hebt
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: stap 1, afbeelding 1 van 2 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: stap 1, afbeelding 2 van 2
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: stap 2, afbeelding 1 van 2 How to Fix a Misaligned Desk Drawer: stap 2, afbeelding 2 van 2
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: stap 3, afbeelding 1 van 2 How to Fix a Misaligned Desk Drawer: stap 3, afbeelding 2 van 2
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: stap 4, afbeelding 1 van 1
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: stap 5, afbeelding 1 van 1
    • Enjoy your fully functioning drawer!
Conclusie
Dante Mazzanti
598 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 16,616
