Ga door naar hoofdinhoud
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Wat je nodig hebt
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 1, afbeelding 1 van 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 1, afbeelding 2 van 2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 2, afbeelding 1 van 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 2, afbeelding 2 van 2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 3, afbeelding 1 van 1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 4, afbeelding 1 van 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 4, afbeelding 2 van 2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 5, afbeelding 1 van 1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 6, afbeelding 1 van 1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 7, afbeelding 1 van 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: stap 7, afbeelding 2 van 2
    • Tighten the two screws using a JIS #00 screwdriver.
Conclusie
5 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 51
Altijd: 1,817
