Ga door naar hoofdinhoud
How to Fix a Loose Gate Latch on a Wooden Gate
Wat je nodig hebt
  1. How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: stap 1, afbeelding 1 van 2 How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: stap 1, afbeelding 2 van 2
    • Remove all screws and bolts holding your gate latch down.
    • I utilized a Phillips #2 screwdriver and 1/2 in. wrench to complete this task, however your individual gate latch may require other specified sized tools.
  2. How to Fix a Loose Gate Latch on a Wooden Gate: stap 2, afbeelding 1 van 1
    • Remove the gate latch and verify you cannot shift the gate latch to create new holes.
  3. How to Fix a Loose Gate Latch on a Wooden Gate: stap 3, afbeelding 1 van 1
    • Sand the entire work area with 80 Grit sandpaper and an electric sander.
  4. How to Fix a Loose Gate Latch on a Wooden Gate: stap 4, afbeelding 1 van 2 How to Fix a Loose Gate Latch on a Wooden Gate: stap 4, afbeelding 2 van 2
    • Use an electric drill and and a 3/8 inch carbide drill bit to create the 3/8 in. pilot holes for the anchors that will be installed.
  5. How to Fix a Loose Gate Latch on a Wooden Gate: stap 5, afbeelding 1 van 3 How to Fix a Loose Gate Latch on a Wooden Gate: stap 5, afbeelding 2 van 3 How to Fix a Loose Gate Latch on a Wooden Gate: stap 5, afbeelding 3 van 3
    • Using a hammer, tap in the sleeve anchors with the washer and bolt still attached, to prevent the sleeve and anchor bolt from separating.
    • Keep tapping the sleeve anchor until most of the sleeve is seated in the wood while leaving 12.7 mm of thread protruding from the wood.
    • This will allow you to be able to reinstall the gate latch.
    • Remove the bolts and washers from Sleeve Anchors once they have been inserted into the piloted holes.
  6. How to Fix a Loose Gate Latch on a Wooden Gate: stap 6, afbeelding 1 van 3 How to Fix a Loose Gate Latch on a Wooden Gate: stap 6, afbeelding 2 van 3 How to Fix a Loose Gate Latch on a Wooden Gate: stap 6, afbeelding 3 van 3
    • Reposition the gate handle and the gate latch.
    • Use a a 1/2 inch wrench to fasten the salvaged hardware onto the gate latch.
    • Reattach the gate latch and handle with the new hardware from the sleeve anchors with a 1/2 inch wrench.
Conclusie
Nicholas Stockdale
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 128
Altijd: 1,111
