Ga door naar hoofdinhoud
How to Fix a Loose Connector in an Anivia 1080p Webcam
Wat je nodig hebt
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 1, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 1, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 1, afbeelding 3 van 3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 2, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 2, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 2, afbeelding 3 van 3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 3, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 3, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 3, afbeelding 3 van 3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 4, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 4, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 4, afbeelding 3 van 3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 5, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 5, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 5, afbeelding 3 van 3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 6, afbeelding 1 van 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 6, afbeelding 2 van 2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 7, afbeelding 1 van 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 7, afbeelding 2 van 2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 8, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 8, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 8, afbeelding 3 van 3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 9, afbeelding 1 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 9, afbeelding 2 van 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: stap 9, afbeelding 3 van 3
    • Snap the faceplate covering back into place.
Eindstreep
Duncan Holloway
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 53
Altijd: 880
