Ga door naar hoofdinhoud
How to Fix a Leaning Wooden Gate
Wat je nodig hebt
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: stap 1, afbeelding 1 van 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: stap 1, afbeelding 2 van 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: stap 2, afbeelding 1 van 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: stap 3, afbeelding 1 van 3 How to Fix a Leaning Wooden Gate: stap 3, afbeelding 2 van 3 How to Fix a Leaning Wooden Gate: stap 3, afbeelding 3 van 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: stap 4, afbeelding 1 van 3 How to Fix a Leaning Wooden Gate: stap 4, afbeelding 2 van 3 How to Fix a Leaning Wooden Gate: stap 4, afbeelding 3 van 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: stap 5, afbeelding 1 van 2 How to Fix a Leaning Wooden Gate: stap 5, afbeelding 2 van 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: stap 6, afbeelding 1 van 2 How to Fix a Leaning Wooden Gate: stap 6, afbeelding 2 van 2
    • Remove the object you placed underneath.
Conclusie
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
133 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 463
