Ga door naar hoofdinhoud
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
Wat je nodig hebt
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 1, afbeelding 1 van 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 1, afbeelding 2 van 2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 2, afbeelding 1 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 2, afbeelding 2 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 2, afbeelding 3 van 3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 3, afbeelding 1 van 1
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 4, afbeelding 1 van 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 4, afbeelding 2 van 2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 5, afbeelding 1 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 5, afbeelding 2 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 5, afbeelding 3 van 3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 6, afbeelding 1 van 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 6, afbeelding 2 van 2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 7, afbeelding 1 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 7, afbeelding 2 van 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: stap 7, afbeelding 3 van 3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
Conclusie
Your lock will not jam anymore!
Één andere persoon heeft deze handleiding voltooid.
Manpreet Sahota
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 66
Afgelopen 30 dagen: 286
Altijd: 14,059
